Discussion topic: Wifi is
This message was authored by: Whitey17
Wifi is
WiFi isn't working and TVs aren't working
This message was authored by: Allie36
Re: Wifi is
Mine aren't either, according to the app my services are good. Yet there's a red light on my router for internet and voice.
the power light and the wifi lights are green
Re: Wifi is
@Whitey17
If your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them so they can look in to this for you.
