Discussion topic: No wifi
Message posted on 16 Jan 2026 01:21 PM
No wifi
No WiFi. 3 lights middle 1 stays red. All listed tests done twice.
Just stopped working all of a sudden.
What else can I tell you about this?
Message posted on 16 Jan 2026 01:23 PM
Re: No wifi
@Denise132
See further down for guidance on the lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
