Discussion topic: Wifi is slow
This message was authored by: Juliet111
Wifi is slow
The wifi is incredibly slow. I run the tests and it's saying that everything is working as it should. But I cannot even my gmail properly. Please help?
Re: Wifi is slow
@Juliet111
Do you have a weak or poor signal because a poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
