Discussion topic: Wifi is not working
This message was authored by: Wallistombs
Wifi is not working
My wifi is not working and my app is detecting an issue but not fixing it
Re: Wifi is not working
@Wallistombs
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
