Discussion topic: No wifi
This message was authored by: Nikki011
No wifi
Unable to get Internet connection
Re: No wifi
@Nikki011
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
