Discussion topic: Wifi is down
This message was authored by: Jimmy17
Wifi is down
The WiFi has gone down and all the lights have gone off on the openreach box. I have run a test and it says its all working fine. I've turned the router and the sky q box off at the plug but still nothing had come back on. All the sky is off too. Please can you help?
Re: Wifi is down
@Jimmy17  Is there a red light on the Openreach box or as you said no life in it at all?
Avatar for Jimmy17
Re: Wifi is down
Everything is back up and running now. Thank you for getting back to me.
Re: Wifi is down
@Jimmy17  Keep an eye on it and any more problems then just come back.
