Discussion topic: Wifi has been cutting out for days now
This message was authored by: O13
Internet keeps loosing connection. The light is now off after flashing amber over a few hours.
Re: Wifi has been cutting out for days now
@O13 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
