Discussion topic: Broadband not working
Message posted on 13 May 2025 03:43 PM
Power light green internet light orange WiFi light green voice light orange have tried power reboot still got the same lights on the router
Message posted on 13 May 2025 03:53 PM
Re: Broadband not working
@Raffles25-_
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
