Discussion topic: Wifi dropping out
Message posted on 02 Oct 2025 03:59 PM
Wifi dropping out
Message posted on 02 Oct 2025 04:04 PM
Re: Wifi dropping out
@MITTI
If you are having broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
