Discussion topic: My Alexa keeps cutting off losing connection
This message was authored by: 69+budman
my Amazon echo keeps losing connection plays the radio for awhile and then Will  turn off and lose connection
Re: My Alexa keeps cutting off losing connection
@69+budman Has this just all started happening to the Echo, if not just move it closer to the hub first to establish if a wireless wi-fi signal issue!
Avatar for 69+budman
Yes about two weeks ago, my device is Next Door directly to my router
@69+budman Does this mean you do not want to move it, or think that it does not matter it's close enough!
I cannot get into any closer and I have moved it further away. It does not make any difference as you can say there's nothing wrong with my connection's Wi-Fi speed, et cetera. There's no updates to do on the echo device.
@69+budman What sky hub is the Echo connecting to and also which echo device! See the sky link!
