Discussion topic: Wifi dropping out
This message was authored by: Swhite
Wifi dropping out
Wifi keeps dropping out , reset it countless times but doesn't stay on for more than a minute or two , followed all the instructions on sky's site but nothing helps
Re: Wifi dropping out
@Swhite is it the wifi connection to the device thst is failing or the connection of the hub to the line? The two have totally different causes and therefore how to fix them. As a start look at the leds on the hub when the connection goes down as this trouble shooter will tell you the next step see https://www.sky.com/help/articles/hub-lights-explained-start
Avatar for Swhite
When I run a test it says its all OK but I have had a yellow light all night and now again when I woke up  , so cannot connect anything to the Internet
