Discussion topic: Wifi dropping out
This message was authored by: kazm123
Wifi dropping out
Hi
over the last few days my wifi keeps dropping out. I work from home and need this to stop happening.
Re: Wifi dropping out
@kazm123
In addition~
▪️ Any engineer visit that’s required is still likely to be delayed due to the disruption from the recent storms.
▪️ This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
