1
This discussion topic has been answered Discussion topic: Wifi dropping out regularly
This message was authored by: Maddy53
Hello My wifi is down again, this is happening at least once a day often more
Re: Wifi dropping out regularly
@Maddy53
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
@Maddy53
