Discussion topic: Wifi drop outs
This message was authored by: PeteChalkley
Message posted on 23 Jul 2026 01:12 PM
Wifi drop outs
Hi My wifi signal around the house isnt great and more annoying, I will be on wifi on my phone, then it will stop working, drop off, then slowly reconnect. Clearly the service check says its fine.
Find out more
Message posted on 23 Jul 2026 01:28 PM
Re: Wifi drop outs
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
