Discussion topic: Wifi down
This message was authored by: Baz59
Wifi down
WiFi down
Re: Wifi down
@Baz59  the community needs a little bit more information in order to help you. How long has your broadband been down and have you  ran the service checker. If you haven't follow the directions in the link below.
Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
