Discussion topic: Wifi down
Message posted on 17 Mar 2025 02:39 AM
Wifi down
Wifi stopped working
Message posted on 17 Mar 2025 05:00 AM
Re: Wifi down
It could be overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it hasn't returned by 0700 use the below link to check to see if there are any problems or outages nearby
