Discussion topic: Wifi down walsall
Message posted on 12 Jul 2025 09:03 PM
Wifi down walsall
Na wife keeps going off amd on
Message posted on 12 Jul 2025 10:14 PM
Re: Wifi down walsall
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
Message posted on 12 Jul 2025 10:54 PM
Mine to in Exeter!!?
Message posted on 13 Jul 2025 05:16 AM
Same advice. Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
