Discussion topic: Intermittent internet
Message posted on 12 Jul 2025 11:04 PM
My internet has been going off every 10 mins or so since last Wednesday. I'm trying to work from home and it's impossible
Message posted on 13 Jul 2025 05:13 AM
Re: Intermittent internet
@Clare253
If your broadband isn’t working try this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
