Discussion topic: Wifi down but sky test not picking it up
Message posted on 31 Aug 2026 06:22 PM
We've got no Internet. Running the tests on sky it's not picking up any issues. But the box has no light for Internet or it will flash amber and go blank again.
Message posted on 31 Aug 2026 06:26 PM
Re: Wifi down but sky test not picking it up
@Bsimpson22
You aren’t talking to Sky by posting here. If you are new to the forum then welcome to the Community which is made up predominantly of Sky customers helping other Sky customers which includes additional help from customers who are Superusers like myself.
Firstly it’s worth pointing out that Broadband and Wi-Fi are different. Broadband is the internet connection provided by your ISP (Sky), Wi-Fi is the wireless connection between your hub and devices.
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
