Discussion topic: Wifi down - again
This message was authored by: ASIM5
Wifi down - again
After being off forvover 18 hours, the WiFi connection has failed, yet again.
Checked website and said no problems, but ibviousky there is as been off for over an hour.
I have switched everything off and restarted, bit nothing
Re: Wifi down - again
@ASIM5
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
