Discussion topic: Wifi coverage
This message was authored by: Strawman-house
Wifi coverage
Hi
My wifi is simply not performing as it should?
I have a bad connection onmy wifi for my computer which is in one corner of the house ( same as printer).
I have two TV streaming TV's which continually buffer and we loose contact with SKY completely.
I have one extension hub which I have to keep moving around the house as we have no connection or very low levels.
Can you help?
Re: Wifi coverage
Hi @Strawman-house
Which Sky hub do you have and what package are you on?
You shouldnt keep moving a booster around as it will affect connectivity for the whole house not just that area.
I am NOT a Sky Employee
Avatar for Strawman-house
Re: Wifi coverage
If I don't move the connector I don't get WiFi in some parts of the house.
ske streaming is the process
Re: Wifi coverage
@Strawman-house
Then you should get more boosters from Sky. A booster should be in a fixed position, it is not designed to be moved around.
