Discussion topic: Wifi continuosly dropping out
Message posted on 09 May 2025 03:14 PM
My WiFi is continuously dropping out when I do the broadband and WiFi checks it says everything is fine! When it's quite clearly not. I work from home and this is causing a lot of issues
Message posted on 09 May 2025 04:30 PM
Re: Wifi continuosly dropping out
If you haven't then try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
