Discussion topic: Wifi connection
This message was authored by: CalvinHutt
Wifi connection
Hi my wifi isn't working properly for some reason or another on my tvs and laptop but works fine on my phone! It's saying the network is available but won't connect when we put the password in. Could someone help with this please Thanks
Re: Wifi connection
@CalvinHutt What hub do you have from sky!
Avatar for CalvinHutt
Re: Wifi connection
Hi, I have a Sky Max Hub
Re: Wifi connection
@CalvinHutt Use your working mobile and look at the sky max hub, the wireless is probably on wpa3, go set it to wpa2-psk mode, save and reboot the hub, and see if you can attach the other failing devices on the wi-fi....
Re: Wifi connection
I gave that a go, hasn't worked unfortunately but thanks anyway.
Re: Wifi connection
@CalvinHutt Not finished with it yet, next is disable one off the bands that is all you can do as it is the Sky Max hub, as a temporary method until working.Read this carefully and only the max side, and just disable only ONE off the bands.
Split Sky WiFi bands
