Discussion topic: Wifi connection issues
This message was authored by: Stewart31
Message posted on 24 Mar 2026 03:41 PM
Can't connect tv or sky box to internet. Try rebooting everything still won't connect but connecting to phones ok
This message was authored by: JL31
Message posted on 24 Mar 2026 08:08 PM
Re: Wifi connection issues
We have the same problem did you get yours sorted?
This message was authored by: Squeak_
Message posted on 24 Mar 2026 08:35 PM
I just had everything drop out too.
From what I can see on istheservicedown, looks like there's massive issues across the UK right now, particularly high volumes of reports around London understandably, but would recommend checking to see if the same is true where you are.
