Discussion topic: Telephone post wifi not working
Message posted on 24 Mar 2026 07:50 PM
I seen man working on post but WiFi stopped working at 3 pm will they fix auto or we need to complain.
Message posted on 24 Mar 2026 08:10 PM
Re: Telephone post wifi not working
@kulwantsehmi
You haven’t contacted Sky by posting on here. This is a customer ▶️ customer discussion forum where we try to help other customers.
