Discussion topic: Wifi booster
This message was authored by: Robg246
Wifi booster
How do i get a wifi booster, i recently ordered wifi max, was told its wall to wall wifi and i would receive a booster, but its still not wall to wall and no booster. How can i order one without having to jump through a ridiculous amount of hoops and tests and phone calls. I hust want a booster that i was told i would receive anyway as part of wifi max.
Re: Wifi booster
@Robg246 As long as you have the complete sky Max wi-fi package then you can get a booster, there is NO way to avoid the jumping through hoops, that is required to get even the 1st one organised. You have to call sky to do it all, it's a pain but the only way! If you do not pay the extra supplement then sky will be looking for you to add that to your package, so look on your billing 1st....
There seems to be a lot off confusion NO one get's the booster sent with a single sky Max hub package out off the get GO, the process is call, test, pass requirement's get one, and No's 2-3 are all Engineer visit's as to why they are needed. TOO much wireless wi-fi mesh is just as bad as not having enough especially when there is not controls to look at what is going on! If you want/need a good mesh system then sky is NOT the way to go with that!
getting sky max and how to get the pod's
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
