Discussion topic: Wifi and tv continually not working
Message posted on 09 Apr 2026 04:41 AM
Three days in a row now. No Internet or tv. Sky checker says everything is OK. Every now and again all 4 lights are on and then it defaults back.
Message posted on 09 Apr 2026 05:27 AM
Re: Wifi and tv continually not working
Is this just overnight or all the time?
Message posted on 09 Apr 2026 06:00 AM
Every 20 minutes or so
Message posted on 09 Apr 2026 07:22 AM
@MW80
