Discussion topic: Poor wi go signal
This message was authored by: dannyhunt1976
Poor wi go signal
Hi we have just completed sky broadband but our top 2 floors are getting weak signal our previous provider Ee had to fit 3 signal boosters to get it working but you have only sent 1 I told the advisor this when ordering
Re: Poor wi go signal
@dannyhunt1976
If you have Broadband Max then Sky will supply up to 3 pods so you will need to contact them again about this. 150 is the number to call from your landline phone or you can use this link:
Select "No, I still need help" at the bottom on the above link.
