Discussion topic: Wifi Signal weak around property
This message was authored by: Tony311051
The Broadband Hub is receiving fine, yet around the property the signal is not strong for devices. Also WPA3T connection is a problem.
Re: Wifi Signal weak around property
@Tony311051 some devices that should connect to WPA3-T ( the transitional standard which both WPA3 and WPA2 devices cansupposedly  use) simply dont hence the advice to change the WiFi security standard where this is an issue.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
