1
This discussion topic has been answered Discussion topic: Wi fi weak downstairs
This message was authored by: DanShort
I had broadband and sky tv fitted yesterday, it all works well in our lounge, tv etc is great. I have a weak signal in the rest of the house, the bedroom tv etc are very slow and we only get sporadic speeds downstairs. I didn't have this issue with my previous provider (Now)
Re: Wi fi weak downstairs
@DanShort given Now are part of Sky and use the same equipment what has changed with your new set up? In particular has the hub been changed or moved?
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
