Discussion topic: Wifi Router
This message was authored by: NigelThomson
Message posted on 29 Dec 2024 07:30 AM
Wifi Router
Wifi keeps cutting out resulting in TV pausing and mobile phones loosing signal.
Find out more
Message posted on 29 Dec 2024 08:12 AM
Re: Wifi Router
@NigelThomson is the WiFi signal literally stopping and starting so devices in the same room ose connection or signal further from the hub not being strong enough? The first would be likely due to a faulty hub which Sky should repace but the latter is simply an indication that a single. Hub cannot give coverage through out your home which is a coomon problem which requires paying for additional equipment,
