Discussion topic: WiFi
This message was authored by: Lyndsey1301
WiFi
Hi
we have had issues with WiFi since we have moved in
we only get signal in half the rooms in the house
the signal is constantly dropping
and now the signal won't connect to 2 off our tvs
please can this be looked at asap
This message was authored by: Me134
Re: WiFi
@Lyndsey1301 wrote:
Hi
We're only other customers here, like yourself.
Firstly, unplug the hub for 10 minutes and then reboot.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
