Discussion topic: WiFi
Message posted on 01 Jun 2026 08:27 PM
WiFi
Message posted on 01 Jun 2026 08:32 PM
Re: WiFi
@Frakesky
Even if you’ve already tried it use this link to check if there are any broadband outages or issues locally that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
