3
This discussion topic has been answered Discussion topic: WiFi
This message was authored by: Chrissyr
WiFi
Is it possible to change the password on your router  to stop the kids using WiFi at night
This message was authored by: Me134 Answer
Re: WiFi
If you change the WiFi password that would stop everyone from using it entirely unless they knew what it is. Removing the devices is always the most foolproof method.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Re: WiFi
Not a Sky employee
Re: WiFi
@Chrissyr
If you have Broadband Max then this comes with parental settings:
https://www.sky.com/help/articles/sky-wifi-max-parental-controls
Avatar for Chrissyr
Re: WiFi
Thank you to all for replying I have decided to change the password on the router so only I have the password
