Discussion topic: WiFi
Message posted on 04 Feb 2026 11:20 PM
WiFi
As always Sky Broadband is down yet you report all is ok on a network check! Getting bored of constant problems with Sky now! Ridiculous consuthe amount of money you fleece people
Message posted on 04 Feb 2026 11:45 PM
Re: WiFi
I wasnt able to video chat. My connection was off. Sick of it too
Message posted on 05 Feb 2026 05:57 AM
Re: WiFi
@SiM25
