Discussion topic: WiFi
This message was authored by: LaurenRiley1
WiFi
My WiFi isn't working
Re: WiFi
@LaurenRiley1
See further down for guidance on hub lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
