Discussion topic: WiFi
This message was authored by: Wifinoton
WiFi
No WiFi. Checked all plugs and leads
Re: WiFi
@Wifinoton
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
