Discussion topic: WiFi
Message posted on 05 Jan 2026 10:46 AM
WiFi
The WiFi continuously drops at my house, it is currently down. Please can I get some advice on how to make it more reliable? I work from home so it's crucial to have a good service and I've had nothing but issues since moving to Sky.
Message posted on 05 Jan 2026 10:51 AM
Re: WiFi
@Nic153
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
Message posted on 05 Jan 2026 11:36 AM
Re: WiFi
@Nic153 Does anything from below show to you?
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
