Discussion topic: Interment not working
This message was authored by: Saadhabab
My WiFi has not been working for a few hours. I uploaded some pics
Re: Interment not working
@Saadhabab
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
