Discussion topic: WiFi
This message was authored by: Lydia6
WiFi
My WiFi box is just flashing orange then red!. Tried to reset no good?. Anyone else?
Re: WiFi
@Lydia6
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
