Discussion topic: WiFi issue
This message was authored by: donchester
WiFi issue
All lights, are green on box but no wifi
Re: WiFi issue
@donchester
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
