Discussion topic: WiFi
Message posted on 16 Nov 2025 10:30 AM
WiFi
My WiFi keeps going off it's been happening for over a week and it's not getting any better
Message posted on 16 Nov 2025 10:47 AM
Re: WiFi
@Mccabe1
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
