Discussion topic: WiFi
Message posted on 09 Nov 2025 05:37 PM
WiFi
Message posted on 09 Nov 2025 05:39 PM
Re: WiFi
@CarlaRodrigues
Use this link to check to see if there are any broadband issues or outages nearby, even if you’ve already tried it ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
Message posted on 10 Nov 2025 07:48 AM
WiFi problema
Message posted on 10 Nov 2025 08:45 AM
Re: WiFi problema
@CarlaRodrigues If you suspect that the sky Hub is the problem then give sky a call. they will run diagnostic against it while you are talking with them, that will determine what the see, if it is found to be bad, they will send you a replacement!
