Discussion topic: Internet and tv not working ? What
This message was authored by: Bobbieb71
My internet and tv isn't working it's red on the checking app but when you go I and check services it's saying no issues
Re: Internet and tv not working ? What
@Bobbieb71
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
