Discussion topic: WiFi
Message posted on 10 Sep 2025 08:54 PM
WiFi
My WiFi keeps failing for my sky box. This is the third time that the tv states not connected to the box and I have to fully reset.
this shouldn't be happening and never happened with previous provider.
Did this all evening Saturday.
Message posted on 10 Sep 2025 09:08 PM
Re: WiFi
@Babybeckton What type is the sky Box you are talking about, and what sky Hub is it connected too!
Message posted on 10 Sep 2025 09:24 PM
Re: WiFi
Sky q box with WiFi box sky max hub
Message posted on 10 Sep 2025 09:27 PM
Re: WiFi
@Babybeckton Two links below for what you need, and the sky Max hub WPA2-PSK through the app would be the setting to change. Also see the sky Q connected as a THIRD party device, it has to be that way!.
sky connecting devices
https://www.sky.com/help/articles/connect-devices-to-broadband-start
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
