Discussion topic: WiFi
This message was authored by: -andy-
WiFi
I have no WiFi through my hub ,everything has gone off.
Re: WiFi
@-andy- Run the service checker link over a mobile data connection if you can, it may let you know if sky are aware off any issues. Link is below for you.
This should determine if there's an identified fault affecting multiple households.
