Discussion topic: WiFi
This message was authored by: Steveytv84
WiFi
Good morning, Yesterday and this morning our WiFi keeps dropping out. It does come back after a few minutes but the test via this app says there are no issues.
Re: WiFi
@Steveytv84
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
