Discussion topic: WiFi
This message was authored by: Donna93
WiFi
My WiFi keeps cutting of
Re: WiFi
@Donna93
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
If you’re still having problems you may need to call Sky to report it. Dial 150 free from your Sky Talk landline (if it’s still working) although the lines are currently down due to technical difficulties.
