Discussion topic: WiFi
This message was authored by: Susancrosb
WiFi
Hi WiFi keeps going off its happened for 2 days now
Re: WiFi
@Susancrosb
If you’re still having problems you may need to call Sky to report it (dial 150 free from your Sky Talk landline [if it’s still working]).
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
