Discussion topic: WiFi
This message was authored by: Rochelle4
WiFi
Over the last few days my WiFi keeps dropping out which is not great when you have sky TV this is happening at least once a day if not more.
I also work from home so require the Internet for this reason also
Re: WiFi
@Rochelle4
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
